kboot import
Question asked by Kenneth Tait on May 23, 2016
Latest reply on May 25, 2016 by Alice_Yang
Setup is KDS on linux 64 bit,
trying to set up a kboot project.
If I set up a new workspace and import with copy of the desired target, it sets it up but does not copy all the source files , only I2C driver??? and complains about paths being wrong, but does make an elf file..
If I switch to the bootloader folder as the workspace and select a project, it trashes stuff.
There is no way to directly open the workspace under \kds folder.
so WHAT is the EXACT procedure for setting up a bootloader project that does not modify the original sources...
Reference manual only shows an IAR setup..which I don't care about...
Ken
