Dear All,
I am reading in the Kinetis SDK 2.0 API. Is this really correct?
static void SPI_Enable(I2C_Type *base, bool enable);
Shouldn't it be SPI_Type *?
Cheers
Niklas
Solved! Go to Solution.
Niklas,
You are correct, this is the incorrect type specified in the SPI_Enable function prototype.
Thanks for bringing this to our attention. I've verified that this issue has been fixed in the latest version of the driver. I've also requested an update to our online API documentation, which should already be in place.
Jason
Niklas,
Jason
