Flash programmer does not come up as a possible target task for LS2085A.
Suede
I am using the following version of CodeWarrior
I want to define a target task for flash programming, but I don't get Flash Programmer as a choice.
Only import/Export/Fill Memory comes up in the dialogue box.
yipingwang
Hello Bo Karlsson,
The procedure for flash programming on LS2085 with CodeWarrior is different with PowerPC or LS1 platform.
After install CodeWarrior for ARMv8, please refer to "Chapter 7 Flash Programmer" in CW4NET_v2016.01\CW_ARMv8\ARMv8\Help\PDF\ARMv8_Targeting_Manual.pdf to do flash programming.
Yiping
addiyi
Bo,
Please use the latest CW for ARMv8 release, and not CW for APP.
Adrian
