Can not exit Bus Fault Handler
Question asked by Oliver Schmid on May 23, 2016
Latest reply on May 30, 2016 by EARL GOODRICH
Hi. I have the problem, that I can not exit the Bus Fault Handler.
Here is my code:
startup:
BusFault_Handler\
                PROC
                EXPORT  BusFault_Handler          [WEAK]
                IMPORT  BusFault_ISR_Handler
                LDR         R0, =BusFault_ISR_Handler
                BX        R0
                ENDP
main(){
//Enalbe Bus Fault exception
SCB->SHCSR |= SCB_SHCSR_BUSFAULTENA_Msk;
void BusFault_ISR_Handler(void){
     int test = 1;
