Error While Debugging with Kinetic TWR-K53N512
communitycommun
Hello
   while debugging the MED-BPM code in IAR it shows some time of errors
the error is attached below
ivadorazinova
please, can you also attach debug log files?
Please, did you follow all these steps?
http://cache.nxp.com/files/microcontrollers/doc/user_guide/MEDBPMQSG.pdf?fromsite=zh-Hans
Thank you for your feedback!
Best Regards
Iva
communitycommun
The Debug log files say's as below:
Tue May 24, 2016 09:27:57: Missing or malformed flash loader specification file: C:\Program Files\IAR Systems\Embedded Workbench 7.3\arm\config\flashloader\Freescale\FlashK60Xxxx.board
for the past few day's its working very fine,suddenly these type of error has started from yesterday after the system restart
ivadorazinova
please can you try this trick?
Which .board file is correct for FRDM-K20D50M?
Please let me know, if this helps you.
Iva
communitycommun
Thanks Iva...
its working now...it was helpful ,before your post i have also got the information from another site too..
Thanks for the support
communitycommun
I am already following that steps which you listed in PDF....
This program was running successfully,it collapsed after system restart
