Hi Peg,
Thank you for your response. Unfortunately, neither zip I was able to open with my Codewarrior V6.1. Some error occurs?
Is there simple lines I can use, I do know that the SCI must be initialized and set for its baud rate and receive/send functionality, but I am more interested in the actual line that says write and how it is performed.
Thank you so much...
