Restart MMPF0100 by i.MX6.
satoshishimoda
Senior Contributor I
Hi community,
Our partner have a question about MMPF0100.
They want to restart MMPF0100 from i.MX6 by I2C access.
I guess, it is possible MMPF0100 PWRCTL register PWRONRSTEN bit or RESTARTEN bit.
But there is no description about PWRCTL register.
So would you let me know the description of this register, and whether can we restart MMPF0100 from iMX6?
Satoshi Shimoda
Yuri
  please look at Table 124 (PWRCTL field descriptions) of the following :
http://cache.nxp.com/files/analog/doc/data_sheet/PF3000.pdf
Yuri.
Yuri
  The PWRCTL register (at add 1B) fields may be found in Table 136 (Functional
Page) of the PMIC Datasheet.
http://cache.nxp.com/files/analog/doc/data_sheet/MMPF0100.pdf
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
satoshishimoda
Dear Yuri,
Yes, Table 136 provides the PWRCTL register fields, but no detail is provided about these fields.
So would you let me know the detail of PWRCTL fields to judge whether our partner can use the fields for MMPF0100 reset.
Satoshi Shimoda
Yuri
Yuri.
