Decimal value of 0x1M?
vigneshbalaji
Senior Contributor I
    I want to know the decimal value of 0x1M???
Is 0x1M - 0x1800  = 0x000FF000  ???
jeremyzhou
Before answer your question, I was wondering if you can share the total codes.
I'm looking forward to your reply.
Ping
vigneshbalaji
    I am trying to understand this document which I have attached in the thread.I want to understand listing 10 in it, How my_text section gets it's start address and is it from m_text origin plus length of m_text which will give my_text start address????
jeremyzhou
The 0x1M means 0xFFFFF, and the range of the my_text segment is from the 0x000FF000 to 0x000FFFFF.
Hope it helps.
Ping
