I see from the NXP web site that the Kinetis Bootloader v2 does not support the K70 device. Is there work being done on the porting of this application to the K70? If so, is there a date that I can expect this to be available and/or is a pre-release available?
Hi Bill
You can get KBOOT compatible UART/USB code for the K70 at http://www.utasker.com/kinetis/TWR-K70F120M.html
This allows you to build with IAR, Keil, KDS, CW, Crossworks, Green Hills etc. and optionally mix KBOOT mode with USB-MSD, Memory stick, Ethernet, SD-card etc. according to http://www.utasker.com/docs/uTasker/uTaskerSerialLoader.PDF
Mark
