Cross compile openssh use imx6ul toolchain
Question asked by gaoyuan on May 17, 2016
Latest reply on May 17, 2016 by igorpadykov
I've built standalone toolchian for imx6ul, and install it.
When I  compiled openssh using the toolchain and running it on target board, then I got “Segmentation fault” error.
I think it caused by CFLAGS or LDFLAGS but I don't know how to modify it.
So should someone help me, thank you!
followed is my cross-compile flowchart:
$ git branch
* V_7_2
  master
$ autoconf
$ autoheader
$ export CFLAGS="$CFLAGS -I/data/lib/openssl-1.0.2f/include/ -fPIC"
$  export LDFLAGS="-L/data/lib/openssl-1.0.2f/"
$ ./configure --with-ssl-dir=/data/modules/c0402.git/lib/openssl-1.0.2f --with-zlib=../zlib.git/ --host=arm-poky-linux-gnueabi
OpenSSH has been configured with the following options:
                     User binaries: /usr/local/bin
                   System binaries: /usr/local/sbin
               Configuration files: /usr/local/etc
                   Askpass program: /usr/local/libexec/ssh-askpass
                      Manual pages: /usr/local/share/man/manX
                          PID file: /var/run
  Privilege separation chroot path: /var/empty
            sshd default user PATH: /usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin
                    Manpage format: doc
                       PAM support: no
                   OSF SIA support: no
                 KerberosV support: no
                   SELinux support: no
                 Smartcard support:
                     S/KEY support: no
              MD5 password support: no
                   libedit support: no
  Solaris process contract support: no
           Solaris project support: no
         Solaris privilege support: no
       IP address in $DISPLAY hack: no
           Translate v4 in v6 hack: yes
                  BSD Auth support: no
              Random number source: OpenSSL internal ONLY
             Privsep sandbox style: seccomp_filter
              Host: arm-poky-linux-gnueabi
          Compiler: arm-poky-linux-gnueabi-gcc  -march=armv7-a -mfloat-abi=hard -mfpu=neon -mtune=cortex-a7 --sysroot=/data/toolchain/imx-a7/sysroots/cortexa7hf-vfp-neon-poky-linux-gnueabi
    Compiler flags:  -O2 -pipe -g -feliminate-unused-debug-types -I/data/lib/openssl-1.0.2f/include/ -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wformat-security -Wsizeof-pointer-memaccess -Wno-pointer-sign -Wno-unused-result -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -ftrapv -fno-builtin-memset -fstack-protector-strong -fPIE
Preprocessor flags: -I../zlib.git/
      Linker flags: -L../zlib.git/ -L/data/lib/openssl-1.0.2f/ -Wl,-z,relro -Wl,-z,now -Wl,-z,noexecstack -fstack-protector-strong -pie
         Libraries: -lcrypto -ldl -lutil -lz  -lcrypt -lresolv
and modify LDFLAGS in Makefile to:
"LDFLAGS=-L. -Lopenbsd-compat/ -L../zlib.git/ -L/data/lib/openssl-1.0.2f/ -shared"
$ make
