Hello Murali Kondapi,
Do you use CodeWarrior for PA 10.5?
Which processor do you use?
Do you use CodeWarrior JTAG configuration file to override RCW function? If so, please note that the processor type in the JTAG file is the same with the project and your target.
Yiping
Yiping
