The flash memory array integrity self check problem
xiaobozheng
Hello:
     I test your sw example on our MPC5744P(IN65H) board, but it can not working normal.  Attached is my test program, please help me to test it on your board. thanks!
Original Attachment has been moved to: flash.zip
Original Attachment has been moved to: Example_MPC5744P_FlashArrayIntegrityCheck_test_SSD_v1_0-GHS614.zip
lukaszadrapa
I can see that the function FlashIntegrityCheckFromRAM is not copied to RAM memory by startup files. You have to modify the startup file to copy also appropriate segment or copy the function manually in main.c.
Lukas
