Problem loading .abs file with P&E Multi and MC13213
Question asked by Dan Sweet on Mar 4, 2008
Latest reply on Mar 5, 2008 by Tom Thompson
Hi, I have just started using an MC13213 mcu with a P&E HCS08/HCS12 usb multilink pod. I am having difficulties loading my .abs file into the mcu using the hiwave debugger through the p&e device. When it begins running the programming script, it runs these commands:
Loading programming algorithm ... Done. (FCDIV=$CA)
CMD>EM
Erasing. Module has been erased.
CMD>PM
Programming and Verifying Address $0182C
... at this point it just stalls. It doesn't produce an error, and says its running the programming script, but it never finishes. I get the same results if I use the Expert Mode Programmer to exectue these commands individually. I didn't have a problem loading a simple small test program, but with my current larger project I can't get around this problem. Any ideas? Let me know if you need any other info. Thanks
Dan Sweet
J2MEJediMaster added MCU type to subject line
Message Edited by J2MEJediMaster on 2008-03-05 10:55 AM
