denny george
difference btwn the CPU clk and BUS clk - HCS908AW32
Discussion created by denny george on Mar 3, 2008
Latest reply on Mar 5, 2008 by denny george
Hello All.
I want to know the difference btwn the CPU clk and BUS clk. HCS908AW32 has max of 20mhz bus and cpu clk of 40 mhz. Does that mean that code will run at 40 mhz??or at bus clk of 20 mhz?? Can you give me any timing diagram links?? Ultimately which has the upper hand ? Bus or CPU clk ??
Denn
Added p/n to subject.
Message Edited by NLFSJ on 2008-03-03 08:47 AM
