hello there:
My mpc8313 BSP version is MPC8313E_RDB_K26_20081226-LTIB,
I compile valgrind by select valgrind package while doing ./ltib -c,
and I put the following files to the mpc8313 board under path /dev/shm;
files: cachegrind , callgrind, helgrind ,lackey ,libcoregrind.a , massif ,
memcheck ,none ,valgrind, valgrind-listener, vgpreload_core.so ,
vgpreload_helgrind.so ,vgpreload_massif.so, vgpreload_memcheck.so .
then do as follows:
#ls
cachegrind | libcoregrind.a | valgrind-listener |
callgrind | massif | vgpreload_core.so |
helgrind | memcheck | vgpreload_helgrind.so |
lackey | none | vgpreload_massif.so |
leak | valgrind | vgpreload_memcheck.so |
#export VALGRIND_LIB=/dev/shm
#./valgrind --tool=memcheck ./leak
it give out like this:
valgrind: failed to start tool 'memcheck' for platform 'ppc32-linux': No such file or directory
while doing:
#./valgrind --tool=./memcheck ./leak
valgrind: failed to start tool './memcheck' for platform 'ppc32-linux': No such file or directory
will you give some advices how to use valgrind on mpc8313?
the attach is files I put on the mpc8313 board
Thanks.
Original Attachment has been moved to: valgrind_files.tar.gz
