How do the app autioRoute work ?
Thanks.
Hi ferdinand,
Which codec are you use , if it is WM8960, you can refer to the thread in our community:
and About the Android APK installation/permission
Hope this can help you
Have a nice day
Dan
I know how to run the AudioRoute.apk, I means the audioRoute code had set variable "persist.audio.pass.through", but there is no effect,and I didn't find any code that is related to this variable in the android .
Thanks.
