Dear team,
We are trying to automate some of the functionalities in codewarrior IDE. For example,
Is it possible to automate above steps?. If so, could you please provide me some example code using python/perl ?
Whether Microsoft COM(Component Object Mode) support is there for codewarrior?.
Tool
details:
CodeWarrior for MCU
Version:
10.6
Build
Arnd
Hi Arnd,
Here are a few articles which might be helpful:
https://mcuoneclipse.com/2012/04/12/scripting-the-debugger-shell-getting-started/
https://mcuoneclipse.com/2012/07/29/debugger-shell-test-automation/
https://mcuoneclipse.com/2013/10/26/eclipse-command-line-code-generation-with-processor-expert/
https://mcuoneclipse.com/2012/08/03/codewarrior-flash-programming-from-a-dos-shell/
https://mcuoneclipse.com/2012/08/02/standalone-flash-programmer/
https://mcuoneclipse.com/2015/08/31/programming-kinetis-with-codewarrior-from-the-dos-shell/
Erich
Take a look at Erich Styger's comments on a similar thread here: https://community.freescale.com/thread/301974#comment-307010
