HI,
Am new to NFC.
May be this question is small or repeated in the community.
My question is how can I read the data from the NFC chip, Do I need special tool. Is there any way in the PHP programming where I can connect to the NFC and read all the data. If there is any solution Please let me know.
The reference for Documentation, blogs or videos everything will be really helpful.
Since this is a question not containing enough information here is a list you should go through:
What Architecture?
Which OS?
What NFC-Hardware are you using?
How is the NFC-Chip connected to your device?
What are you planning to do?
