Hello
In the *.ld file, I would like to know what is meaning of PAD() like below.
.heap ALIGN(16) PAD(1K) : {} > int_sram /* Heap Area */
.stack ALIGN(4) PAD(STACK_SIZE) : {} > stack_ram /* Stack Area */
Thank you.
kiminkim You didn't wrote what your compiler is...
In case of GreenHills, it is explicitly written in the documentation:
PAD(value)
Places value bytes of padding (in zeros) at the beginning of the section. This is equivalent to specifying padding at the beginning of the section contents.
For example, the following two definitions are equivalent:
.stack pad(0x10000) : {}
.stack : { . += 0x10000; }
I'll not call your question "stupid", but I think will be very helpful if you spend some time to read your compiler documentation and learn how to use search tool in the provided Help...
