PLL
Question asked by Divija Katabathuni on May 6, 2016
Latest reply on May 6, 2016 by soledad
Hi, generally when does the clock initialisation takes place? There is a situation in my project where if the PLL register is not set(PLL register is set during clock initialisation) then the clock frequency is assigned with value 0 and hence in the next line in the code DIVIDE_BY_ZERO issue was seen.
So, I want to know, by any chance, will PLL ctrl register will be inactive?
Thanks in advance
