We want to use PAD_GPIO01 (PWM2) to generate 2MHz output
We use memtool set register to generate 2MHz
1.Set CCM_CCGR4 to enable pwm2 clock
2.Set PAD_GPIO01 to PWM mode
3.Set PWM2 register, I try to set PWM Sample Register and PWM Period Register to generate output,but I can't understand how to generate 2MHz output
here are my questions1.Can imx6 PWM support 2MHz output?
2.How to set?
Best Regards
Hi charles
please look at description of pwm programming at
sect.27.6.1 Configuring the PWM output attached document
and example from sdk.
