Example of multicore interrupt each other of MPC5775k
zhangsan123
Does MPC5775K has the mechanism of multicore interrupt each other, could you give the example? thanks.
zhangsan123
This is what I need. thanks. David!
davidtosenovjan
Not sure if I understand what you need to know - but if you ask how to interrupt first core by second core and vice versa then you may need software interrupt (sources 0-15).
In particular INTC_PSRn register you are selecting which core is the interrupt request sent to. This way you can initiate interrupt to one core by code executed by second core.
