PMF Modul S12ZVML128
Question asked by Hajer Balti on May 6, 2016
Latest reply on May 10, 2016 by Radek Sestak
Hi, I am using S12ZVML128 to derive a DC Motor, I have initialized the PMF Module in complementary mode low side fixed to drive in two directions (use only PWM pais A & B). After first ECU programming I get correct PWM outputs. But after power on Reset all PWM outputs are set to Null (application is still running, there is LIN communication). Any idea what is the issue?
