I.MX6 DDR Calibration Fail with EMCP memory
david5icp
Hi Community,
  We has a new design using IMX6q with emcp (LPDDR2 + eMMC, Micron MT29PZZZ8D5BKFTF) chip. I want to use ddr calibration tool to get paramater for ddr, I had try several different config files to test my board. But allways fail and show "ERROR FOUND, we can't get suitable value !!!!"
  Does it support this emcp memory ? And who i to check it ? Thanks!
Original Attachment has been moved to: MX6Solo_lpddr2-17.inc.zip
Original Attachment has been moved to: Calibration-Fail.log.zip
Labels (2)
Tags (2)
Yuri
  Please try using the recent DDR stress test (it provides calibration options too).
i.MX6/7 DDR Stress Test Tool V2.52
  Also, it makes sense to check PCB trace requirements :
- DQS signals should be 5 – 200 mils shorter than the clocks.
- Data and respective DQM signals should be 5 – 25 mils shorter than
  corresponding DQSs.
- Address and control signals should be 5 – 25 mils shorter than the clocks.
- Longest clock trace must be <= 3 inches.
  As for DRAM configuration tool, please try the following
i.MX6DQ LPDDR2 Register Programming Aid
Yuri
