Hi all
We are using MQX 3.7 with the MFS extension for sd cards. Now we would like to use sd cards greater than 4GB. Unfortunately we found out that the routine 'MFS_Get_disk_free_space' just can handle drives smaller than 4GB.
But in the current documentation of the MFS we have seen that newer versions of MFS are extended and can managing sd cards bigger than 4GB.
Is it possible to to update the MFS part of the MQX 3.7 for example with the one of MQX 4.2?
Kind regards
Stephan
Hello Stephan,
Unfortunately there are significant changes between both versions and it is not supported to modify only the MFS part.
I suggest to migrate your project to the latest release.
Sol
