PE DMA Controller Issues
Question asked by David XY Zhou on Apr 28, 2016
Latest reply on May 8, 2016 by Alice_Yang
I have K60F120M tower board.
I have issues with ISR event callback problem and want to remove the DMA controller and regenerate through PE. But after I removed DMA controller, I couldn't put it back as the same as before. I copied back the saved version, but The order of the channels in the Property page (attached) is not Chan 0 to Chan 3.
which creates a huge problem for me after PE generated code.
All channel numbers are reassigned into a different number, e.g. DMACH1 should be DMA1_STATIC_CHANNEL_1, but it reassigned to DMA1_STATIC_CHANNEL_3 even the Channel is chan 1 in the DMA1 controller as shown above.
The green line is new code generated by PE and the red line is removed/changed from previously generated code.
How to fix it?
Thank you,
David Zhou
