KL03 power required to run CMP and 6-bit DAC in standby mode?
thomasedel
I can't find any data regarding the power used by the KL03 comparator while in standby mode (when using the CMP and 6-bit DAC in trigger mode; while waiting to be triggered).  Some documents imply lower power than normal enabled-mode power, but I can't find any specifics. Some specs show the the normal enable-mode current to be about 15uA to 25uA (typical or maximum for low power mode), but I don't see any data for standby mode while waiting for a trigger.
Thanks in advance for any help with this.
-Thomas
vicentegomez
Hi Thomas
I am not sure if this what you are looking for
Please check the table 11 in the data sheet
Vicente Gomez
