using CF Flasher for 28F256J3(1x8)
gillesvanborren
Hello, currently I use on a MCF54452 of 28F128J3F75A flash.
The programming of these flash is accomplished by cf-flasher Version 3.1.10 using 28F128J3D(1x8).alg file.
I would change the flash to use 28F256J3F95 (always 8bit access). Could you tell me how to get the "xxxx (1x8).alg" file for these flash?
miduo
Please be note that CFflasher is EOL for serveral years and we do not provide any technical support for it any more. You can still use it with our evaluation board but no any support to change the flash algorithm.
