I have configured imx6 sabrelite board with yocto(jethro) linux kernel version 3.14.28-1.0.0 as webcam gadget and I have tried to play video from ov5640 camera connected to board. For that I have used uvc-gadget application with patches applied. What happens is that exception is thrown at moment I open uvc video on windows for playing:
./uvc-gadget -f 0 -o 1 -r 0 -s 1 -u /dev/video4 -v /dev/video1
UVC: IO method requested is USER_mxc_cam_select_input: input(0) CSI IC MEM
PTR
ov5640_download_autofocus(mipi): Downloaded firmware successfully: 0
ov5640_set_virtual_channel: virtual channel=2
V4L2 device is on bus
V4L2: Getting current format: YU12 288x352
V4L2: Setting format to: YUYV 640x360
V4L2: Getting current format: YUYV 640x360
v4l2 open succeeded, file descriptor = 3
uvc device is 2184000.usb on bus gadget
uvc open succeeded, file descriptor = 4
V4L2: Buffer 0 mapped at address 0x76da4000.
V4L2: Buffer 1 mapped at address 0x76d33000.
V4L2: 2 buffers allocated.
streaming request (req 81 cs 01)
streaming request (req 83 cs 01)
streaming request (req 82 cs 01)
streaming request (req 01 cs 01)
setting probe control, length = 26
streaming request (req 01 cs 01)g_webcam gadget: uvc_function_set_alt(1, 1)
streaming request (req 81 cprp_enc_setup:in:640x480 out:640x360 format=56595559
s 01)
streaming request (req 01 YUYV
cs 02)
setting commit control, length = 26
UVC: 2 buffers allocated.
Dev memmap requested!
V4L2: Starting video stream.
------------[ cut here ]------------
WARNING: CPU: 0 PID: 1011 at /home/dubravski/boundary/jethro/boundary-eval-image/tmp/work-shared/nitrogen6x/kernel-source/arch/arm/mm/ioremap.c:301 __arm_ioremap_pfn_caller+0xd4/0x1b0()
Modules linked in: g_webcam uvcvideo videobuf2_vmalloc videobuf2_memops videobuf_vmalloc adxl362(O) c130_mipi(O) brcmfmac brcmutil cfg80211 usb_f_ecm usb_f_rndis u_ether libcomposite ov5642_camera ov5640_camera_mipi mxc_v4l2_capture ipu_bg_overlay_sdc ipu_still ipu_prp_enc ipu_csi_enc ipu_fg_overlay_sdc v4l2_int_device snd_soc_fsl_asrc galcore(O) [last unloaded: g_ether]
CPU: 0 PID: 1011 Comm: uvc-gadget Tainted: G W O 3.14.28-1.0.0_ga+yocto+g2ffd4a4 #17
Backtrace:
[<80011dd8>] (dump_backtrace) from [<80011fe8>] (show_stack+0x18/0x1c)
r7:8001bda0 r6:0000012d r5:808b925c r4:00000000
[<80011fd0>] (show_stack) from [<8063b544>] (dump_stack+0x84/0xc4)
[<8063b4c0>] (dump_stack) from [<8002e748>] (warn_slowpath_common+0x74/0x90)
r5:00000009 r4:00000000
[<8002e6d4>] (warn_slowpath_common) from [<8002e808>] (warn_slowpath_null+0x24/0x2c)
r8:30100000 r7:808a9b34 r6:00030100 r5:00000000 r4:00071000
[<8002e7e4>] (warn_slowpath_null) from [<8001bda0>] (__arm_ioremap_pfn_caller+0xd4/0x1b0)
[<8001bccc>] (__arm_ioremap_pfn_caller) from [<8001becc>] (__arm_ioremap_caller+0x50/0x58)
r9:7f1cc21c r8:00071000 r7:00000000 r6:76da4000 r5:9c70c1c0 r4:8001be7c
[<8001be7c>] (__arm_ioremap_caller) from [<8001bba0>] (__arm_ioremap+0x20/0x24)
[<8001bb80>] (__arm_ioremap) from [<7f1cc388>] (vb2_vmalloc_get_userptr+0x16c/0x1c4 [videobuf2_vmalloc])
r5:9c70c1c0 r4:9c7be030
[<7f1cc21c>] (vb2_vmalloc_get_userptr [videobuf2_vmalloc]) from [<8043e0c8>] (__qbuf_userptr+0x90/0x318)
r8:8093aa08 r7:9c5ab9f8 r6:9c824c00 r5:9c7bfb80 r4:9c824c00
[<8043e038>] (__qbuf_userptr) from [<8043f708>] (__buf_prepare+0x200/0x244)
r10:9c7bfe28 r9:9c5ab8cc r8:9cae3180 r7:9c60f538 r6:9c7bfe28 r5:9c5ab920
r4:9c824c00
[<8043f508>] (__buf_prepare) from [<804409e4>] (vb2_internal_qbuf+0x7c/0x170)
r9:9c5ab8cc r8:9cae3180 r7:9c824c00 r6:00000000 r5:9c7bfe28 r4:9c5ab920
[<80440968>] (vb2_internal_qbuf) from [<80440b10>] (vb2_qbuf+0x38/0x58)
r7:9c5aba40 r6:9c7bfe28 r5:9c5ab920 r4:9c5ab800
[<80440ad8>] (vb2_qbuf) from [<7f1e82d8>] (uvc_v4l2_do_ioctl+0x2f0/0x538 [g_webcam])
[<7f1e7fe8>] (uvc_v4l2_do_ioctl [g_webcam]) from [<8042f360>] (video_usercopy+0x1cc/0x4bc)
r9:7e8da898 r8:00000003 r7:00000044 r6:00000044 r5:00000000 r4:c044560f
[<8042f194>] (video_usercopy) from [<7f1e77b4>] (uvc_v4l2_ioctl+0x18/0x1c [g_webcam])
r10:00000000 r9:7f1e779c r8:9c5ab850 r7:9c73c540 r6:7e8da898 r5:c044560f
r4:9c5a8400
[<7f1e779c>] (uvc_v4l2_ioctl [g_webcam]) from [<8042b7c8>] (v4l2_ioctl+0xf0/0x168)
[<8042b6d8>] (v4l2_ioctl) from [<800f8c80>] (do_vfs_ioctl+0x3e8/0x5dc)
r9:9c7be000 r8:7e8da898 r7:00000004 r6:9c73c540 r5:9cb984c0 r4:7e8da898
[<800f8898>] (do_vfs_ioctl) from [<800f8eb0>] (SyS_ioctl+0x3c/0x64)
r9:9c7be000 r8:7e8da898 r7:c044560f r6:9c73c540 r5:00000004 r4:9c73c540
[<800f8e74>] (SyS_ioctl) from [<8000e7c0>] (ret_fast_syscall+0x0/0x30)
r9:9c7be000 r8:8000e944 r7:00000036 r6:00000001 r5:7e8daa18 r4:00000000
---[ end trace 6c7d6c587ca44098 ]---
UVC: Unable to queue buffer 0: In------------[ cut here ]------------
valid argument (22).
UVC: UnableWARNING: CPU: 1 PID: 1011 at /home/dubravski/boundary/jethro/boundary-eval-image/tmp/work-shared/nitrogen6x/kernel-source/arch/arm/mm/ioremap.c:301 __arm_ioremap_pfn_caller+0xd4/0x1b0()
to queue buffer 1: Invalid argumModules linked in: g_webcam uvcvideo videobuf2_vmalloc videobuf2_memops videobuf_vmalloc adxl362(O) c130_mipi(O) brcmfmac brcmutil cfg80211 usb_f_ecm usb_f_rndis u_ether libcomposite ov5642_camera ov5640_camera_mipi mxc_v4l2_capture ipu_bg_overlay_sdc ipu_still ipu_prp_enc ipu_csi_enc ipu_fg_overlay_sdc v4l2_int_device snd_soc_fsl_asrc galcore(O) [last unloaded: g_ether]
ent (22).
CPU: 1 PID: 1011 Comm: uvc-gadget Tainted: G W O 3.14.28-1.0.0_ga+yocto+g2ffd4a4 #17
Backtrace:
r8:30180000 r7:808a9b34 r6:00030180 r5:00000000 r4:00071000
r9:7f1cc21c r8:00071000 r7:00000000 r6:76d33000 r5:9c566340 r4:8001be7c
r5:9c566340 r4:9c7be030
r8:8093aa08 r7:9c5ab9f8 r6:9c824800 r5:9c7bfb80 r4:9c824800
r4:9c824800
r9:9c5ab8cc r8:9cae3180 r7:9c824800 r6:00000000 r5:9c7bfe28 r4:9c5ab920
r4:9c5a8400
r9:9c7be000 r8:8000e944 r7:00000036 r6:00000002 r5:7e8daa18 r4:00000000
---[ end trace 6c7d6c587ca44099 ]---
g_webcam gadget: uvc_function_set_alt(1, 0)
setting probe control, length = ERROR: v4l2 capture: Capture stream has been turned on
26
streaming request (req 01 cs 02)
V4L2: Unable to start streaming: Operation not permitted (1).
Backtrace:
r9:7f1cc21c r8:00071000 r7:00000000 r6:76da4000 r5:9c5662c0 r4:8001be7c
r5:9c5662c0 r4:9c7be030
r8:8093aa08 r7:9c5ab9f8 r6:9c5a8800 r5:9c7bfb80 r4:9c5a8800
r4:9c5a8800
r9:9c5ab8cc r8:9cae3180 r7:9c5a8800 r6:00000000 r5:9c7bfe28 r4:9c5ab920
r4:9c5a8400
r9:9c7be000 r8:8000e944 r7:00000036 r6:00000003 r5:7e8daa18 r4:00000000
---[ end trace 6c7d6c587ca4409a ]---
Backtrace:
r9:7f1cc21c r8:00071000 r7:00000000 r6:76d33000 r5:9c5662c0 r4:8001be7c
r8:8093aa08 r7:9c5ab9f8 r6:9c5aa400 r5:9c7bfb80 r4:9c5aa400
r4:9c5aa400
r9:9c5ab8cc r8:9cae3180 r7:9c5aa400 r6:00000000 r5:9c7bfe28 r4:9c5ab920
r4:9c5a8400
r9:9c7be000 r8:8000e944 r7:00000036 r6:00000004 r5:7e8daa18 r4:00000000
---[ end trace 6c7d6c587ca4409b ]---
UVC: Unable to queue buffer 1: Invalid argument (22).
What I have did wrong?
There is also warning thrown when I start g_webcam.ko driver:
gadget# insmod g_webcam.ko
g_webcam gadget: uvc_function_bind
WARNING: CPU: 1 PID: 1005 at /home/dubravski/boundary/jethro/boundary-eval-image/tmp/work-shared/nitrogen6x/kernel-source/drivers/media/v4l2-core/videobuf2-core.c:2218 vb2_queue_init+0x18c/0x194()
Modules linked in: g_webcam(+) uvcvideo videobuf2_vmalloc videobuf2_memops videobuf_vmalloc adxl362(O) c130_mipi(O) brcmfmac brcmutil cfg80211 usb_f_ecm usb_f_rndis u_ether libcomposite ov5642_camera ov5640_camera_mipi mxc_v4l2_capture ipu_bg_overlay_sdc ipu_still ipu_prp_enc ipu_csi_enc ipu_fg_overlay_sdc v4l2_int_device snd_soc_fsl_asrc galcore(O) [last unloaded: g_ether]
CPU: 1 PID: 1005 Comm: insmod Tainted: G O 3.14.28-1.0.0_ga+yocto+g2ffd4a4 #17
Backtrace:
r7:80440960 r6:000008aa r5:808b925c r4:00000000
r8:9c5ab804 r7:7f1e8d00 r6:9c5ab800 r5:9cae3180 r4:9c5ab920
[<8002e7e4>] (warn_slowpath_null) from [<80440960>] (vb2_queue_init+0x18c/0x194)
[<804407d4>] (vb2_queue_init) from [<7f1eb71c>] (uvc_function_bind+0x37c/0x4c4 [g_webcam])
r5:9cae3180 r4:9c5ab874
[<7f1eb3a0>] (uvc_function_bind [g_webcam]) from [<7f118930>] (usb_add_function+0x60/0x108 [libcomposite])
r10:7f1e8738 r9:7f1e8784 r8:7f1e8760 r7:7f1e8d00 r6:7f1e874c r5:7f1e8d00
r4:9c5ab874
[<7f1188d0>] (usb_add_function [libcomposite]) from [<7f1eba60>] (uvc_bind_config+0x1fc/0x248 [g_webcam])
r5:9c5ab800 r4:7f1e8ddc
[<7f1eb864>] (uvc_bind_config [g_webcam]) from [<7f1ebae4>] (webcam_config_bind+0x38/0x40 [g_webcam])
r10:7f1e8eac r9:00000000 r8:00000000 r7:9cae3180 r6:00000000 r5:7f1ebaac
r4:7f1e8d00
[<7f1ebaac>] (webcam_config_bind [g_webcam]) from [<7f1196ac>] (usb_add_config+0x38/0xe0 [libcomposite])
[<7f119674>] (usb_add_config [libcomposite]) from [<7f1eb36c>] (webcam_bind+0x54/0x88 [g_webcam])
r9:9ce3a010 r8:00000000 r7:9c392218 r6:00000000 r5:9cae3180 r4:7f1e8cac
[<7f1eb318>] (webcam_bind [g_webcam]) from [<7f11aebc>] (composite_bind+0xa0/0x198 [libcomposite])
r5:7f1e8e50 r4:9cae3180
[<7f11ae1c>] (composite_bind [libcomposite]) from [<803f8da4>] (udc_bind_to_driver+0x34/0xd8)
r10:7f1e8eac r9:9ce3a010 r8:00000000 r7:00000005 r6:7f1e8e50 r5:7f1e8e50
r4:9c3c6600
[<803f8d70>] (udc_bind_to_driver) from [<803f8ec0>] (usb_gadget_probe_driver+0x78/0xa8)
r7:00000005 r6:7f1e8e50 r5:7f1e8e50 r4:808ca658
[<803f8e48>] (usb_gadget_probe_driver) from [<7f119508>] (usb_composite_probe+0xc0/0xcc [libcomposite])
r5:7f1e8be0 r4:7f1e8e28
[<7f119448>] (usb_composite_probe [libcomposite]) from [<7f1ebb04>] (webcam_init+0x18/0x1c [g_webcam])
r7:9c842080 r6:9c842088 r5:00000001 r4:7f1ebaec
[<7f1ebaec>] (webcam_init [g_webcam]) from [<80008878>] (do_one_initcall+0x104/0x160)
[<80008774>] (do_one_initcall) from [<8008f000>] (load_module+0x1970/0x202c)
r9:7f1e8eb8 r8:00000001 r7:9c842080 r6:9c842088 r5:00000001 r4:9ce3bf48
[<8008d690>] (load_module) from [<8008f854>] (SyS_finit_module+0x8c/0x9c)
r10:00000000 r9:9ce3a000 r8:8000e944 r7:0000017b r6:00028ec0 r5:00000003
r4:00000000
[<8008f7c8>] (SyS_finit_module) from [<8000e7c0>] (ret_fast_syscall+0x0/0x30)
r6:00000000 r5:00000000 r4:00c5b008
---[ end trace 6c7d6c587ca44097 ]---
g_webcam gadget: Webcam Video Gadget
g_webcam gadget: g_webcam ready
Are there any patch to fix this problems for yocto(jethro) linux, because from forum search I have found that patches for other linux version exists but I can not apply them on my linux version.
Thanks, regards, Ivan.
Maybe this could help you:
USB Video Class Gadget Library - libguvc - RidgeRun Developer Connection
Marco
I have the same problem, have you solved it?
could you tell me how to config the kernel as webcam gadget ?
Thank you very much
you have to enable web cam hid in menuconfig.
device drivers
usb
gadget
web_cam gadget.
Bitbake the image.
Unload other hid driver. rmmod g_ether.ko, or other if installed.
lsmod lists drivers loaded.
And when start linux go in lib/modules/yocto.../kernel/usb/gadget/ and
insmod g_wecam.ko.
You also have to load other dirvers before that in dir .../kernel/v4l2/
(or something like that) and insmod memory_alloc drivers so webcam would
work. I am currently not able to reproduce everything because my board
is not working.
