Is the loopback mode of flexcan in MPC8039 supported?
Question asked by carl peng on Apr 27, 2016
Latest reply on May 4, 2016 by lunminliang
Thank you in advance!
I have the questions as below:
1. Does mpc8039 flexcan support loopback mode?
    During debug, I found that I can soft reset the flexcan successfully, but when I try to send messages out through MB in the loopback mode, it failed. I found the code field in the MB always as the value I wrote into it, 0xC, it is never changed.
2.  If I set the flexcan in normal mode, I will can not access the flexcan regsiter address space, I should set the mode as
     supervisor mode, then I can access flexcan address space, but still can not access "RX Individual Mask Registers",
    Why?
