Hi,any possible to read/write CPU card with PN532
hongprove
Hi, I want to try to read/write the CPU card with PN532, and is it possible to do it with the uart commands, and any examples or suggests can you tell me? Thanks!!
weidong_sun
Hello Prove,
     PN532 supports UART / I2C/ SPI interfaces to communicate with Host. So it is no problem for you to use UART. you can run Serial Tool on OS and interfact with PN532 by sending commands.
     For detailed command format, please refter to PN532 user's manul.
Weidong
