Where is it that the timeout for trying to get a dhcp address can be changed?
Solved! Go to Solution.
Hi Michael:
Do you mean the dhcp termination timeout? if yes, it is 60s.
ipcfg_bind_dhcp_wait is a blocking function, which means it does not return until ipcfg_bind_dhcp is finished, and ipcfg_bind_dhcp timeout value is 60s.
Please check the macro in rtcsglob.c
uint32_t _RTCS_dhcp_term_timeout = 60;
Hi Michael:
