GstAiurDemux:aiurdemux0: GStreamer encountered a general stream error.
Question asked by m.c on Apr 26, 2016
Latest reply on May 11, 2016 by Joan Xie
Board: MCIMX6Q-SDB
OS: Yocto 3.14.28
Test procedure:
export GST_DEBUG=0,aiurdemux:5
./loop.sh
Error message:
0:04:44.452914034   620 0x75f25800 DEBUG              aiurdemux /home/mike/yocto/fsl-release-bsp/imx6qsabresd/tmp/work/imx6qsabresd-poky-linux-gnueabi/gst1.0-fsl-plugin/4.0.3-r0/gst1.0-fsl-plugins-4.0.3/plugins/aiurdemux/aiurdemux.c:3173:aiurdemux_push_pad_buffer:<aiurdemux0> audio push sample 0:01:53.290158000 size 551 is discont: 0 is delta unit: 0
ERROR: from element /GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstAiurDemux:aiurdemux0: GStreamer encountered a general stream error.
0:04:44.453402034   620 0x75f25800 DEBUG              aiurdemux /home/mike/yocto/fsl-release-bsp/imx6qsabresd/tmp/work/imx6qsabresd-poky-linux-gnueabi/gst1.0-fsl-plugin/4.0.3-r0/gst1.0-fsl-plugins-4.0.3/plugins/aiurdemux/aiurdemux.c:3173:aiurdemux_push_pad_buffer:<aiurdemux0> video push sample 0:01:53.313200000 size 5008 is discont: 0 is delta unit: 1
Additional debug info:
/home/mike/yocto/fsl-release-bsp/imx6qsabresd/tmp/work/imx6qsabresd-poky-linux-gnueabi/gst1.0-fsl-plugin/4.0.3-r0/gst1.0-fsl-plugins-4.0.3/plugins/aiurdemux/aiurdemux.c(1000): aiurdemux_pull_task (): /GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstAiurDemux:aiurdemux0:
streaming stopped, reason error, state 3
ERROR: pipeline doesn't want to preroll.
Original Attachment has been moved to: 20160426-mcimx6qsdb-imx6y31428101-gst-debug-06.txt.zip
Original Attachment has been moved to: loop.sh
