ke02z run only in debug
Question asked by Suraj KA on Apr 26, 2016
Latest reply on Apr 27, 2016 by Suraj KA
I am using processor expert with keil. The problem is that my program runs in debug only. It's not running at por. As I read in the other threads, there is no "librarian" settings found in PE. I am running from internal oscillator. 32khz oscillator is connected but not configured to use. Another problem is that I have to flash the program before debugging(= flashing two times, one when starting debugging and another before that).
Using my own board, opensda that comes with fdrm-ke02z. Fdrm processor is disconnected removing jumper resistor
. Kindly help. Thank you.
