I have seen implementations like MCAT and Quickstart that do provide the utility, but they are supported on limited devices. I need to do some calculation in an xls and use the answers in software. I do not want to copy paste them time and again. Is there any utility/method that can help?
Solved! Go to Solution.
Hello Ankur
Eclipse CodeWarrior for MCU supports exporting trace data to Excel, as well as the registers information. But I cannot find a way to import the data into CodeWarrior from Excel. However, you can open Excel file directly in CodeWarrior, just drag the file into IDE. Before it, please make sure that the "Allow in-place system editors" option is checked.
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
Hello Ankur
Best Regards
Fiona Kuang
