We are interfacing MPC5775K with MR2001V (VCO) by SPI
The Write commands are sent as expected . But doing a read does not read the set variables values
Enclosed is SPI code.
Original Attachment has been moved to: spi_rfs.c.zip
at first, please look at this example which shows, how to correctly set SPI as a master/slave and how to communicate between these two nodes.
Martin
