FCCU_init in “while(FCCU.CTRL.B.OPS != 0x3);” not passed.
DELPHI_Eric
FCCU not passed, about watchdog ?
When injected into a fake failure before commissioning through. But injecting a fake uncorrectable flash ecc fault will be through, not passing through a phenomenon does not pass.In “while(FCCU.CTRL.B.OPS != 0x3);” not passed.When the initial programming is not passed, the next power-down re-burn through.Thanks! !
MENU undetectable uncorrectable flash ecc fault after power failure, after a uncorrectable flash ecc fault is detected after be reloaded.
Original Attachment has been moved to: memu.h.zip
Original Attachment has been moved to: memu.c.zip
davidtosenovjan
In attached code you have commented out calling of ClearNCF() function.
All faults must be cleared before entering FCCU config state.
DELPHI_Eric
Hi! David,   I find,reset MEMU_SYS_RAM_UNCERR_STS  VLD bit = 0 can through debugging while(FCCU.CTRL.B.OPS != 0x3) .
NOTE
The reporting table is not cleared on software reset.
ClearMEMU_ERR_FLAG();
FCCU_Init();
test_22 = MEMU_handler();
Generate_noncorrectable_FLASH_ECC_error();
Thanks!
davidtosenovjan
OK. And what is your issue now?
DELPHI_Eric
No, thank you very much for your help.
