Sub :- USB pen drive not auto mounted / unmounted in imx6 kitkat
Dear Sir,
we have developed a custom board using imx6DL processor.
We have developed android kitkat 4.4.2 for this board.
When we are connecting usb pen drive then in dmesg it is shown as sda.
But it is not get mounted anywhere. If we manually mount it then we can see contents of pen drive.
If we remove pen drive and again connected then in dmesg sdb shown.
Means every time pen drive connected new node created for pen drive in /dev/block/ and we have to manually mount it.
Also in Android setting -- storage -- usb storage it is not reflected even after mounting it manually.
Please give some solution for this problem..
Dear Artur,
Thanks for your reply.
I have checked it with box USB host and usb OTG port. I am getting same response.
When usb pen drive connected --- it is detected as /dev/block/sda ----- but not mounted
If we remove pen drive that also detected sda get removed from /dev/block.
IF we manually mounted then we have to manually unmount it. Otherwise second time it will detected as /dev/block/sdb.
Driver loaded for this pen drive is usb_storage.
In our kitkat 4.4.2 we are missing something because of auto mounting and unmounting of usb pen drive in Host as well as OTG not working.
If you can provide some check points, it will be helpful for us.
I have checked it on my i.MX6Q SABRE SD board with the original KK4.4.2 BSP by NXP/FSL - everything works fine, i.e. an USB storage device is always detected as sda, auto-mounted and becomes visible in the Android Settings - > Storage menu. So, the problem is specific for your custom system, either in hardware or in software. By the way, what USB port do you use, OTG or Host?
Artur
usb pen drive detection / undetection logs for both OTG and Host are as below
ehci_fsl_bus_resume begins, DR
ehci_fsl_bus_resume ends, DR
usb 1-1: new high speed USB device number 8 using fsl-ehci
usb 1-1: device not accepting address 8, error -71
usb 1-1: new high speed USB device number 9 using fsl-ehci
usb 1-1: new high speed USB device number 10 using fsl-ehci
usb 1-1: device v0930 p6544 is not supported
scsi1 : usb-storage 1-1:1.0
usb 1-1: USB disconnect, device number 10
fsl-ehci fsl-ehci.0: port 1 reset error -110
usb 1-1: new high speed USB device number 11 using fsl-ehci
usb 1-1: new high speed USB device number 12 using fsl-ehci
scsi2 : usb-storage 1-1:1.0
scsi 2:0:0:0: Direct-Access Kingston DataTraveler G3 1.00 PQ: 0 ANSI: 2
sd 2:0:0:0: [sda] 3913664 512-byte logical blocks: (2.00 GB/1.86 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 0b 00 00 08
sd 2:0:0:0: [sda] No Caching mode page present
sd 2:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 2:0:0:0: [sda] Attached SCSI removable disk
root@var_som_mx6:/ # ls -l /dev /blroot@var_som_mx6:/ # ls -l /dev/block/
loop0 loop4 mmcblk0 mmcblk0p2 mmcblk0p6 sda
loop1 loop5 mmcblk0boot0 mmcblk0p3 mmcblk0p7 sda1
loop2 loop6 mmcblk0boot1 mmcblk0p4 mmcblk0p8 vold/
loop3 loop7 mmcblk0p1 mmcblk0p5 platform/
brw------- root root 7, 0 1970-01-01 00:00 loop0
brw------- root root 7, 1 1970-01-01 00:00 loop1
brw------- root root 7, 2 1970-01-01 00:00 loop2
brw------- root root 7, 3 1970-01-01 00:00 loop3
brw------- root root 7, 4 1970-01-01 00:00 loop4
brw------- root root 7, 5 1970-01-01 00:00 loop5
brw------- root root 7, 6 1970-01-01 00:00 loop6
brw------- root root 7, 7 1970-01-01 00:00 loop7
brw------- root root 179, 0 1970-01-01 00:00 mmcblk0
brw------- root root 179, 8 1970-01-01 00:00 mmcblk0boot0
brw------- root root 179, 16 1970-01-01 00:00 mmcblk0boot1
brw------- root root 179, 1 1970-01-01 00:00 mmcblk0p1
brw------- root root 179, 2 1970-01-01 00:00 mmcblk0p2
brw------- root root 179, 3 1970-01-01 00:00 mmcblk0p3
brw------- root root 179, 4 1970-01-01 00:00 mmcblk0p4
brw------- root root 179, 5 1970-01-01 00:00 mmcblk0p5
brw------- root root 179, 6 1970-01-01 00:00 mmcblk0p6
brw------- root root 179, 7 1970-01-01 00:00 mmcblk0p7
brw------- root root 259, 0 1970-01-01 00:00 mmcblk0p8
drwxr-xr-x root root 1970-01-02 00:02 platform
brw------- root root 8, 0 1970-01-02 00:02 sda
brw------- root root 8, 1 1970-01-02 00:02 sda1
drwx------ root root 1970-01-01 00:00 vold
root@var_som_mx6:/ # ls -l /s
sbin/ seapp_contexts storage/ system/
sdcard/ sepolicy sys/
root@var_som_mx6:/ # ls -l /s troot@var_som_mx6:/ # ls -l /storage/ udroot@var_som_mx6:/ # ls -l /storage/udisk/
root@var_som_mx6:/ # usb 1-1: USB disconnect, device number 12
ehci_fsl_bus_suspend begins, DR
ehci_fsl_bus_suspend ends, DR
root@var_som_mx6:/ # ehci_fsl_bus_resume begins, DR
usb 1-1: new high speed USB device number 13 using fsl-ehci
scsi3 : usb-storage 1-1:1.0
scsi 3:0:0:0: Direct-Access Kingston DataTraveler G3 1.00 PQ: 0 ANSI: 2
sd 3:0:0:0: [sda] 3913664 512-byte logical blocks: (2.00 GB/1.86 GiB)
sd 3:0:0:0: [sda] Write Protect is off
sd 3:0:0:0: [sda] Mode Sense: 0b 00 00 08
sd 3:0:0:0: [sda] No Caching mode page present
sd 3:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 3:0:0:0: [sda] Attached SCSI removable disk
root@var_som_mx6:/ # root@var_som_mx6:/ # ls -l /storage/udisk/ root@var_som_mx6:/ # ls -l /dev/block/
brw------- root root 8, 0 1970-01-02 00:03 sda
brw------- root root 8, 1 1970-01-02 00:03 sda1
root@var_som_mx6:/ # usb 1-1: USB disconnect, device number 13
root@var_som_mx6:/ # usb 2-1.1: USB disconnect, device number 3
usb 2-1.1: new high speed USB device number 4 using fsl-ehci
scsi4 : usb-storage 2-1.1:1.0
scsi 4:0:0:0: Direct-Access Kingston DataTraveler G3 1.00 PQ: 0 ANSI: 2
sd 4:0:0:0: [sda] 3913664 512-byte logical blocks: (2.00 GB/1.86 GiB)
sd 4:0:0:0: [sda] Write Protect is off
sd 4:0:0:0: [sda] Mode Sense: 0b 00 00 08
sd 4:0:0:0: [sda] No Caching mode page present
sd 4:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 4:0:0:0: [sda] Attached SCSI removable disk
root@var_som_mx6:/ # root@var_som_mx6:/ # ls -l /dev/block/ root@var_som_mx6:/ # ls -l /storage/udisk/ root@var_som_mx6:/ # ls -l /dev/block/
drwxr-xr-x root root 1970-01-02 00:04 platform
brw------- root root 8, 0 1970-01-02 00:04 sda
brw------- root root 8, 1 1970-01-02 00:04 sda1
root@var_som_mx6:/ # usb 2-1.1: USB disconnect, device number 4
ehci_fsl_bus_suspend begins, Host 1
ehci_fsl_bus_suspend ends, Host 1
root@var_som_mx6:/ # ehci_fsl_bus_resume begins, Host 1
ehci_fsl_bus_resume ends, Host 1
usb 2-1.1: new high speed USB device number 5 using fsl-ehci
scsi5 : usb-storage 2-1.1:1.0
scsi 5:0:0:0: Direct-Access Kingston DataTraveler G3 1.00 PQ: 0 ANSI: 2
sd 5:0:0:0: [sda] 3913664 512-byte logical blocks: (2.00 GB/1.86 GiB)
sd 5:0:0:0: [sda] Write Protect is off
sd 5:0:0:0: [sda] Mode Sense: 0b 00 00 08
sd 5:0:0:0: [sda] No Caching mode page present
sd 5:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 5:0:0:0: [sda] Attached SCSI removable disk
root@var_som_mx6:/ # usb 2-1.1: USB disconnect, device number 5
usb 2-1.1: new high speed USB device number 6 using fsl-ehci
scsi6 : usb-storage 2-1.1:1.0
scsi 6:0:0:0: Direct-Access Kingston DataTraveler G3 1.00 PQ: 0 ANSI: 2
sd 6:0:0:0: [sda] 3913664 512-byte logical blocks: (2.00 GB/1.86 GiB)
sd 6:0:0:0: [sda] Write Protect is off
sd 6:0:0:0: [sda] Mode Sense: 0b 00 00 08
sd 6:0:0:0: [sda] No Caching mode page present
sd 6:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 6:0:0:0: [sda] Attached SCSI removable disk
root@var_som_mx6:/ # usb 2-1.1: USB disconnect, device number 6
root@var_som_mx6:/ # ehci_fsl_bus_suspend begins, Host 1
usb 1-1: new high speed USB device number 14 using fsl-ehci
scsi7 : usb-storage 1-1:1.0
scsi 7:0:0:0: Direct-Access Kingston DataTraveler G3 1.00 PQ: 0 ANSI: 2
sd 7:0:0:0: [sda] 3913664 512-byte logical blocks: (2.00 GB/1.86 GiB)
sd 7:0:0:0: [sda] Write Protect is off
sd 7:0:0:0: [sda] Mode Sense: 0b 00 00 08
sd 7:0:0:0: [sda] No Caching mode page present
sd 7:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 7:0:0:0: [sda] Attached SCSI removable disk
brw------- root root 8, 0 1970-01-02 00:05 sda
brw------- root root 8, 1 1970-01-02 00:05 sda1
root@var_som_mx6:/ # mount root@var_som_mx6:/ # ls -l /dev/block/ root@var_som_mx6:/ # ls -l /storage/udisk/
root@var_som_mx6:/ # mount -t vfat /dev/blroot@var_som_mx6:/ # mount -t vfat /dev/block/ sda1 /ment nt/medev/block/sda1 /mnt/media_rw/ <udat /dev/block/sda1 /mnt/media_rw/udisk/ <
mount: sending ioctl 125d to a partition!
root@var_som_mx6:/ # root@var_som_mx6:/ # mount -t vfat /dev/block/sda1 /mnt/media_rw/udisk/ root@var_som_mx6:/ # ls -l /storage/udisk/
drwx------ root root 1980-01-01 00:00 LOST.DIR
-rwx------ root root 41984 2016-04-22 10:53 device tree.doc
-rwx------ root root 24576 2016-04-14 14:29 imx6 pin multiplexing.doc
root@var_som_mx6:/ # usb 1-1: USB disconnect, device number 14
hub 1-0:1.0: hub_port_status failed (err = -32)
hub 1-0:1.0: Cannot enable port 1. Maybe the USB cable is bad?
hub 1-0:1.0: unable to enumerate USB device on port 1
usb 1-1: new high speed USB device number 19 using fsl-ehci
scsi8 : usb-storage 1-1:1.0
scsi 8:0:0:0: Direct-Access Kingston DataTraveler G3 1.00 PQ: 0 ANSI: 2
sd 8:0:0:0: [sdb] 3913664 512-byte logical blocks: (2.00 GB/1.86 GiB)
sd 8:0:0:0: [sdb] Write Protect is off
sd 8:0:0:0: [sdb] Mode Sense: 0b 00 00 08
sd 8:0:0:0: [sdb] No Caching mode page present
sd 8:0:0:0: [sdb] Assuming drive cache: write through
sdb: sdb1
sd 8:0:0:0: [sdb] Attached SCSI removable disk
root@var_som_mx6:/ # root@var_som_mx6:/ # ls -l /storage/udisk/ root@var_som_mx6:/ # mount -t vfat /dev/block/sda1 /mnt/media_rw/udisk/ root@var_som_mx6:/ # ls -l /storage/udisk/ root@var_som_mx6:/ # ls -l /dev/block/
loop0 loop4 mmcblk0 mmcblk0p2 mmcblk0p6 sdb
loop1 loop5 mmcblk0boot0 mmcblk0p3 mmcblk0p7 sdb1
FAT-fs (sda1): Directory bread(block 7654) failed
FAT-fs (sda1): Directory bread(block 7655) failed
FAT-fs (sda1): Directory bread(block 7656) failed
FAT-fs (sda1): Directory bread(block 7657) failed
FAT-fs (sda1): Directory bread(block 7658) failed
FAT-fs (sda1): Directory bread(block 7659) failed
FAT-fs (sda1): Directory bread(block 7660) failed
FAT-fs (sda1): Directory bread(block 7661) failed
root@var_som_mx6:/ # usb 1-1: USB disconnect, device number 19
