LTIB Build Error
LTIB Build Error
arunachalamrama
I am able to build L3.0.35_4.1.0 on Ubuntu 14.04.
After applying Multimedia Codec, I get error given below.
I tried different solutions suggested in freescale community and other websites. Problem is still there.
Please let me know if this can be solved or another Linux version with Multimedia Codec (gstreamer) support.
Arun
Processing: fsl-alsa-plugins
Build path taken because: no prebuilt rpm,
Testing network connectivity
OK GPP:
Try fsl-alsa-plugins-1.0.25.tar.gz.md5 from the GPP
http://bitshrine.org/gpp/fsl-alsa-plugins-1.0.25.tar.gz.md5:
02:03:28 ERROR 404: Not Found.
Try fsl-alsa-plugins-1.0.25.tar.gz from the GPP
http://bitshrine.org/gpp/fsl-alsa-plugins-1.0.25.tar.gz:
Can't get: fsl-alsa-plugins-1.0.25.tar.gz at ./ltib line 802.
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Thu Apr 21 02:00:05 2016
Ended:   Thu Apr 21 02:03:28 2016
Elapsed: 203 seconds
These packages failed to build:
fsl-alsa-plugins
Build Failed
Exiting on error or interrupt
Labels (3)
jimmychan
I would suggest you to use Yocto BSP. LTIB is old and will not have any new BSP release.
arunachalamrama
Thanks, jimmychan, for the  update and suggestion.
Please suggest Yocto version with gstreamer support.
Arun
arunachalamrama
Downloaded Linux source and MM Codec source from this link: i.MX 6 Q/D/DL/S L3.0.35_4.1.0 GA release
