Program "make" not found in PATH on KDS
corydavis
Hey all,
I am trying to run a program on the FRDM-K82F, and during the build I am getting "make" not found in PATH.
At the same time I am getting Program "arm-none-eabi-gcc" not found in PATH.
I have researched this same error and have not been able to find anything that works for my IDE.
Does anyone know what is causing these errors?
Thanks for any help
corydavis
Yes, I am using KDS 3.0.0. I'm not totally sure how to upload it directly to this thread, but here is the dropbox link.
Dropbox - myProject
Thanks, I appreciate the help.
Cory Davis
ZhangJennie
Hi Cory,
I build your project on my side. I got error as attachment
are those the same error message as your side?
then I found these two files Event.c/Event.h not included in the SW package. can you please double check if the project source codes you sent me are intact?
Jennie Zhang
ZhangJennie
the default KDS3.2 project tool chain setting is as following:
was your project developed by KDS 3.x? can you upload your project here thus we can check it directly?
thanks!
Jennie Zhang
cthhk
此答案靠谱~
