k65 flash erase
Question asked by steve robalino on Apr 20, 2016
Latest reply on Apr 25, 2016 by Jorge_Gonzalez
Im trying to erase flash starting at address 0x14000 for a total of 3 4096 byte sectors. when the erase function is called (Im using SDK 2.0) the code resets - the same occurs when I try to program the flash -
Im running the chip at 120Mhz and the flash clock is 24mhz
Im not using Kboot or other.... its our own code
when I program the very top of flash memory (x1FE000 & x1FF000) the erase and program operation works fine
only at lower memory addresses it fails
