I would like to know how to use Tera Term, with kinetis design studio. I'm using a KL25Z with the Processor Expert code and I don't know if I have to link Tera Term with Kinetis, because in the configurations , I have already connected Tera term to the KL25Z via the COM4 OpenSDA, but when I compile, download and run, even if I have the code ( coming from the tutorial that i followed https://mcuoneclipse.com/2013/11/16/tutorial-using-a-terminal-input-and-output-without-printf-and-sc... ) nothing happen.
Can someone explain me or give me a tutorial to use Tera Term (or Termite, PuTTY...) ?
Thanks.
Solved! Go to Solution.
I recommend you refer this article.
How to use printf() to print string to Console and UART in KDS2.0
can it help you?
Jennie Zhang
I found the solution last night. Your tutorial works but mine is simpler to do and to use after, the guy that wrote mine just forgot to precise to use the port TSI0_CH2 and TSI0_CH3 for the RxD and the TxD, for the KL25Z.
However, thank you for your answer, it can be very useful for other people, lost like me X)
Have a good day,
Romain Lefrançois
I just also sent your comment to the author.Thanks for your feedback.
Jennie Zhang
I found the solution last night. Your tutorial works but mine is simpler to do and to use, the guy that wrote mine just forgot to precise to use the port TSI0_CH2 and TSI0_CH3 for the RxD and the TxD, for the KL25Z.
However, thank you for you answer, it can be useful for other people.
Have a good day,
Romain Lefrançois
can it help you?
Jennie Zhang
