MC56F82748 connection failure by Multlink Universal Rev B
admin
Specialist II
Original Content posted by Li Yang
We find MC56F82748 connection failure by Multilink Universal Rev B, if using Multilink Universal Rev A and Rev C, no such issue. We try to update the firmware of Rev B, it has no effect. Is there a way to solve the issue?
TICS_Fiona
Hello Yang
I’m using Multilink Universal Rev B to program MC56F82748, and have no problem.
Could you please create a new bareboard project for MC56F82748, and do not add your own application code, then debug again with P&E Universal Multilink, does it work well?
If not, please open the Project Properties and go to ‘Run/Debug Settings’, please check whether the Multilink Universal is recognized as below.  If not, please click on ‘FAQ#29’ to check the driver installation.
The latest driver and firmware can be downloaded from:
http://www.pemicro.com/support/downloads_find.cfm
Hope this helps! If not, I would suggest submitting an issue on the P&E forum:
http://www.pemicro.com/forums/index.cfm
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
mohammad_kamil
Hi Li Yang,
can you please raise ticket with PE micro, As it seems this issue is with Multilink software and not DSC.
