tlv320aic23b not working on imx6q based board
Question asked by Regan Govender on Apr 18, 2016
Hi dear Freescale community,
I need help getting the above mentioned codec working on my board. I'm running debian linux,  kernel version 3.10.94. This kernel was given to me by  the board manufacturer.
my set up/Configuration:
imx6  <====>tlv320aic23b
i2c sda <====> i2c sda
i2c clk <====> i2c clk
I2S tx<====>i2s din
I2S rx<====>i2s dout
I2S fsx<====>i2s lrcout
                 ===>i2s lrc in
I2S blck<====>i2s bclk
The codec uses a 12Mhz crystal to generate its own master clock.
I've started testing using aplay:
when i list devices it gives me :
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: imxspdif [imx-spdif], device 0: S/PDIF PCM Playback dit-hifi-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: imxtlv320 [imx-tlv320], device 0: TLV320AIC23 tlv320aic23-hifi-0 []
  Subdevices: 1/1
When i try to play a file:
aplay -v -D hw:1,0 crash.wav
Playing WAVE 'crash.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
Hardware PCM card 1 'imx-tlv320' device 0 subdevice 0
Its setup is:
  stream       : PLAYBACK
  access       : RW_INTERLEAVED
  format       : S16_LE
  subformat    : STD
  channels     : 2
  rate         : 48000
  exact rate   : 48000 (48000/1)
  msbits       : 16
  buffer_size  : 16384
  period_size  : 4096
  period_time  : 85333
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 4096
  period_event : 0
  start_threshold  : 16384
  stop_threshold   : 16384
  silence_threshold: 0
  silence_size : 0
  boundary     : 1073741824
  appl_ptr     : 0
  hw_ptr       : 0
aplay: pcm_write:1939: write error: Input/output error
I've enabled some debug in the codec file. While i exe the aplay command above i get the following debug:
tlv320aic23-codec 0-001a: write 8 = 5d
tlv320aic23-codec 0-001a: read 7 => 42
tlv320aic23-codec 0-001a: write 7 = 42
tlv320aic23-codec 0-001a: write 9 = 1
tlv320aic23-codec 0-001a: read 6 => 5f
tlv320aic23-codec 0-001a: write 6 = 57
tlv320aic23-codec 0-001a: read 6 => 57
tlv320aic23-codec 0-001a: write 6 = 47
tlv320aic23-codec 0-001a: read 6 => 47
tlv320aic23-codec 0-001a: read 5 => 4
tlv320aic23-codec 0-001a: write 5 = 4
tlv320aic23-codec 0-001a: write 5 = c
tlv320aic23-codec 0-001a: read 5 => c
tlv320aic23-codec 0-001a: write 9 = 0
tlv320aic23-codec 0-001a: write 6 = 5f
tlv320aic23-codec 0-001a: write 6 = 5f.
The changes i made to board dtsi tree:
sound {/* Audio codec on LEC-Base R2 carrier */
//compatible = "fsl,imx-audio-sgtl5000";
//model = "imx-i2s-sgtl5000";
compatible = "fsl,imx-audio-tlv320";
        model = "imx-tlv320";
cpu-dai = <&ssi2>;
mux-int-port = <2>;
mux-ext-port = <3>;
audio-codec = <&codec>;
audio-routing =
"MICIN", "Mic Jack",
//"Mic Jack", "Mic Bias",
"LLINEIN", "Line In Left",
"RLINEIN", "Line In Right",
//"Headphone Jack", "HP_OUT",
"Line Out Left", "LOUT",
"Line Out Right", "ROUT",
"Line Out HP Left", "LHPOUT",
"Line Out HP Right", "RHPOUT";
//codec: sgtl5000@0a {/* Audio codec on LEC-Base R2 carrier */
//compatible = "fsl,sgtl5000";
  codec:  tlv320aic23@1a {/* Audio codec on LEC-Base R1 carrier */
        compatible = "ti,tlv320aic23";
reg = <0x1a>;
clocks = <&clks 201>; /* SMARC AUDIO_MCK, actually unused on carrier */
clock-frequency = <12000000>;
VDDA-supply = <&reg_base_3v3>;
VDDIO-supply = <&reg_base_1v8>;
VDDD-supply = <&reg_base_1v8>;
&audmux {/* SMARC I2S0 (or SPI0) */
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_audmux_2>;
status = "okay";
In imx6qdl.dtsi:
&iomuxc {
  audmux {
  pinctrl_audmux_1: audmux-1 {
  fsl,pins = <
  MX6QDL_PAD_SD2_DAT0__AUD4_RXD  0x130b0
  MX6QDL_PAD_SD2_DAT3__AUD4_TXC  0x130b0
  MX6QDL_PAD_SD2_DAT2__AUD4_TXD  0x110b0
  MX6QDL_PAD_SD2_DAT1__AUD4_TXFS 0x130b0
  pinctrl_audmux_2: audmux-2 {
  fsl,pins = <
  MX6QDL_PAD_CSI0_DAT7__AUD3_RXD  0x130b0
  MX6QDL_PAD_CSI0_DAT4__AUD3_TXC  0x130b0
  MX6QDL_PAD_CSI0_DAT5__AUD3_TXD  0x110b0
  MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x130b0
  pinctrl_audmux_3: audmux-3 {
  fsl,pins = <
  MX6QDL_PAD_DISP0_DAT16__AUD5_TXC  0x130b0
  MX6QDL_PAD_DISP0_DAT18__AUD5_TXFS 0x130b0
  MX6QDL_PAD_DISP0_DAT19__AUD5_RXD  0x130b0
My kernel log for the codec:
dmesg | grep tlv
[    3.386271] tlv320aic23-codec 0-001a: codec register 0-001a
[    3.390582] tlv320aic23-codec 0-001a: ASoC: dai register 0-001a #1
[    3.395508] tlv320aic23-codec 0-001a: ASoC: Mapped DAI tlv320aic23-hifi to CODEC tlv320aic23-codec.0-001a
[    3.403811] tlv320aic23-codec 0-001a: ASoC: Registered DAI 'tlv320aic23-hifi'
[    3.409670] tlv320aic23-codec 0-001a: ASoC: Registered codec 'tlv320aic23-codec.0-001a'
[   13.800901] tlv320aic23-codec 0-001a: codec clk_frequency = 24000000
[   13.807278] imx-tlv320 sound.29: ASoC: binding tlv320aic23 at idx 0
[   13.813656] tlv320aic23-codec 0-001a: write f = 0
[   13.823372] tlv320aic23-codec 0-001a: read 6 => 7
[   13.823379] tlv320aic23-codec 0-001a: write 6 = 47
[   13.823591] tlv320aic23-codec 0-001a: write 5 = 4
[   13.823801] tlv320aic23-codec 0-001a: read 0 => 97
[   13.823808] tlv320aic23-codec 0-001a: write 0 = 17
[   13.824151] tlv320aic23-codec 0-001a: read 1 => 97
[   13.824158] tlv320aic23-codec 0-001a: write 1 = 17
[   13.827881] tlv320aic23-codec 0-001a: read 4 => 1a
[   13.827888] tlv320aic23-codec 0-001a: write 4 = 10
[   13.828106] tlv320aic23-codec 0-001a: write 2 = 70
[   13.828317] tlv320aic23-codec 0-001a: write 3 = 70
[   13.831060] tlv320aic23-codec 0-001a: write 9 = 1
[   13.831389] tlv320aic23-codec 0-001a: read 4 => 10
[   13.831401] tlv320aic23-codec 0-001a: read 4 => 10
[   13.831410] tlv320aic23-codec 0-001a: read 4 => 10
[   13.831433] tlv320aic23-codec 0-001a: read 4 => 10
[   13.831442] tlv320aic23-codec 0-001a: read 4 => 10
[   13.831487] imx-tlv320 sound.29: ASoC: probe imx-tlv320 dai link 0 late -2
[   13.831495] imx-tlv320 sound.29: ASoC: probe imx-tlv320 dai link 0 late -1
[   13.831502] imx-tlv320 sound.29: ASoC: probe imx-tlv320 dai link 0 late 0
[   13.831511] imx-tlv320 sound.29: ASoC: probe imx-tlv320 dai link 0 late 1
[   13.831518] imx-tlv320 sound.29: ASoC: probe imx-tlv320 dai link 0 late 2
[   13.831569] tlv320aic23-codec 0-001a: read 6 => 47
[   13.831581] tlv320aic23-codec 0-001a: read 6 => 47
[   13.831613] tlv320aic23-codec 0-001a: read 6 => 47
[   13.831652] tlv320aic23-codec 0-001a: read 6 => 47
[   13.831664] tlv320aic23-codec 0-001a: read 6 => 47
[   13.831774] tlv320aic23-codec 0-001a: read 6 => 47
[   13.831781] tlv320aic23-codec 0-001a: write 6 = 57
[   13.832262] tlv320aic23-codec 0-001a: read 6 => 57
[   13.832269] tlv320aic23-codec 0-001a: write 6 = 5f
[   13.975160] imx-tlv320 sound.29:  tlv320aic23-hifi <-> 202c000.ssi mapping ok
[   13.981848] tlv320aic23-codec 0-001a: read 7 => 1
[   13.985692] tlv320aic23-codec 0-001a: write 7 = 42
[   15.071203] tlv320aic23-codec 0-001a: read 4 => 10
[   15.074933] tlv320aic23-codec 0-001a: read 4 => 10
[   15.078622] tlv320aic23-codec 0-001a: write 4 = 14
[   15.083105] tlv320aic23-codec 0-001a: ASoC: Capture Source DAPM update failed: -5
I'm still checking whether i2c reads/writes to the codc are actually working because if i change the i2c address in the codec node part in dtsi file:
to
codec:  tlv320aic23@2a {
for example, the kernel does not complain. It still enumerates the device somehow. Also note that i have already checked out this post which relates to my issue:
How to enable TLV320 on IMX6Q?
Well there you have it. If anyones got time to check this out and give me some pointers , it'll be great.
Thanks for your time.
Original Attachment has been moved to: lec-imx6.dtsi.zip
Original Attachment has been moved to: tlv320aic23.c.zip
Original Attachment has been moved to: imx-tlv320.c.zip
Original Attachment has been moved to: imx6qdl.dtsi.zip
