Hello
Hello
odilbekurmonov
I want to know how to change UART baud rate for mkw01 board series. Right now I 'm applying directly hal layer but I want to use comera chip with my microcontroller so I'd be appreciated if you could give a hint on that particular issue.
HOW TO CHANGE BAUD RATE ???
antonioconcio
For both SMAC and 802.15.4 stack you just need to call the function "Serial_SetBaudRate()".
Please have a look at the file SerialManager.c for the implementation and the file SerialManager.h for the available baudrates define that I list here below:
I hope that helps,
Antonio
