Where is the JN-RM-2013?
mguc
I need a reference manual of the JN5168 AES Coprocessor. It is referenced in the JN-UG-3087 but can't find it online.
Thank you
Marko
Labels (2)
soledad
Sorry Marko,
Please check attached the document.
Sol
jmesc_
mguc
Sorry, maybe I wasn't clear enough. On page 23 of the "JN516x Integrated Peripherals API User Guide" the JN-RM-2013 is mentioned but there is no API description of the AES coprocessor. I quote:
"Note that the Integrated Peripherals API does NOT include functions to control the:
  • 128-bit AES Hardware Encryption core built into the JN516x device - this is controlled using the functions described in the AES Coprocessor API Reference Manual (JN-RM-2013)
I found a short description in the Header-Files, which is fine for me at the moment. But it would be nice to have a look at the JN-RM-2013.
Thank you
Marko
soledad
Hello Marko,
Please check the below link and let me know if this helps!!
http://cache.nxp.com/documents/user_manual/JN-RM-2003.pdf
Sol
mguc
Hello again,
it's been a while. This is still not the right documentation... Can you provide me a link to AES Coprocessor API Reference Manual (JN-RM-2013)not JN-RM-2003 or any other! Thanks.
With kind regards
Marko
soledad
Sorry Marko,
Sol
