Launching screen hangs on 94%
neilporven
Senior Contributor I
I am getting hanged up on the following screen:
It stays at 94% and never continues past this.  I also find it annoying that the Cancel button doesn't respond
once pressed.
By the way, the software compiles without errors and I tried re-building it several times and have also done
a clean on it.  If I load another software, it seems to load fine, so there isn't a hardware/multilink issue with
the board.
Can someone explain why this is happening?
Neil Porven
neilporven
Hi Erich,
I followed the link you sent me and it described the issue, exactly!  I followed your fix and sure enough, the debug execution
completed all the way through.
Excellent, thank you much.
I will update my KDS to 3.2.0 to avoid this in the future.
Neil
neilporven
Thank you Erich,
Quick update, if you want to see the code and experience the issue.
I am using the following:
C:\Freescale\SDK_2.0_K64F\boards\frdmk64f\driver_examples\sdcard\polling\kds
Just load that, compile it, plug in your P&E to your FRDMK64F evaluation board and you should
see what I am seeing.
Neil
