Dear community,
The datasheet lists an Operating Temperature Range of -40C to +85C.
Is this range ,Ta (ambient temperature) or Tc ?
I hope to get the Tc range.
Koichi Sakagami
Solved! Go to Solution.
Dear Koichi-san,
Based on the ThetaJC value (~70°C/W) and very small max power dissipation (~600uW), the max difference between junction temp (Tj) and top of package temp (Tc) is only ~0.04°C. So it does not make much sense to distinguish between Tj, Tc and Ta for such a low power device.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
Dear Koichi-san,
Tomas
