Is MK22FN1M0AVLH12 pre-programmed with flashloader?
jennywang
I read through the forum, found a list of MCUs pre-programmed with flashloader which doen't  have MK22FN1M0AVLH12 listed. Doe Flashloader support this MCU now? What is in this IC's flash when it goes out from factory? If it's empty, can I order pre-programmed ICs with my bootloader ported from bootloader 1.2?
Jenny
jeremyzhou
Hi Jenny,
The MK22FN1M0AVLH12 contains the Flashloader in the Flash from the factory as the Fig1 shows.
Ping
jennywang
But From 3/2015's post, the K22_120 family doesn't include 1Mb version.  And from test, looks like the IC is empty. Please verify the flashloader support the particular IC MK22FN1M0AVLH12.
Jenny
