S8KEAZ128 aeabi_idiv
enricoserretti
Hello all,
I'm working with S8KEAZ128 MCU and CodeWarrior tools with GCC. When i try to divide two integer I have errors about __aeabi_idiv() function missing. I suppose that I have to link some floating point libraries, but I don't know how to do this. Someone can help me ? Thanks.
Enrico Serretti
enricoserretti
Hi all,
sorry for delay in my reply. Something had gone wrong during CodeWarrior installation. I have reinstalled CodeWarrior and everything went ok.
Thanks and regards,
Enrico.
bobpaddock
Senior Contributor III
Make sure the libgcc.a archive is in the path you specify in your Makefile.
If still have issue add -lm to the linker to scan the math library.
Do not install gcc in a path that has spaces.
Carlos_Mendoza
Hi Enrico,
Could you tell us which CodeWarrior version are you using? Also, can you attach a sample project so we can reproduce the issue?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
